Anti sway bars
R Wyler
01-07-2005 14:49:38
I am going to get a set of the bars that run along side the lift arms for my 8n. I was looking through the archives here and see that different terms are used for them. Anyhow my question is are the ones that New Holland sells a finer quality than the ones at TSC and those place's? Also are the NH toplinks any better? I am going to get the drawbar fot the lift arms for now and the bars that go up to the top link. I am not going to use it for any substantial pulling as I know it posses a real role over danger. Really just moving my implements around and trailers etc. I appriciate your help.
SteveB(wi)
01-08-2005 11:42:09
 Re: Anti sway bars in reply to R Wyler, 01-07-2005 14:49:38
Dimensions if you want to make your own.
R Wyler
01-08-2005 13:36:36
 Re: Anti sway bars in reply to SteveB(wi), 01-08-2005 11:42:09
Thanks for the info. I'll keep that in mind. Some of these parts get pricey.
( Pic ) Ken N Tx
01-08-2005 09:06:54
third party image
R Wyler
01-08-2005 13:34:26
 Re: Anti sway bars in reply to ( Pic ) Ken N Tx, 01-08-2005 09:06:54
Thanks for the pic Mine has the brackets under the axles or else that kit would be the thing. I didn't know those bars were bent on the ends the ones I used were straight
Ron/PA
01-07-2005 21:20:16
It doesn't take much to controll the sway. I usually only use one sway bar, and that does fine. I made my own, and while I can't recall the measurements on the holes, a piece of ½ inch flat drilled with 1" holes works fine. You may have to grind down the ½" thickness so that you can snap a lynch pin in place, but you'll never need to buy a new set. As for the top link, I only use the turnbuckle type of adjustables, and with all that can go wrong with them or how they may be abused, I buy TSC and keep a spare on hand. Ron
R Wyler
01-08-2005 13:32:13
 Re: Anti sway bars in reply to Ron/PA, 01-07-2005 21:20:16
Thanks I never thought of useing just one. Yes they could be made easily. Yes the turn buckle style is all I will use.
souNdguy
01-07-2005 21:08:26
The ones at TSC work.. but understand.. that for 7 bucks.. you are buying some pretty thin steel. A pair of them will keep a mower steady though. I'm sure mail order or NH will be a better 'grade'.
Soundguy
R Wyler
01-08-2005 13:29:28
 Re: Anti sway bars in reply to souNdguy, 01-07-2005 21:08:26
LOL Yeah I know what you mean some of that cheap junk is not much. Sometimes when some things break they can cause a safety hazard and that is always something to keep in mind
Mike OH
01-07-2005 15:13:53
Probably for what you are going to use them for these parts from either supplier would work fine for you. In my case I come to learn you usually get what you pay for. When it comes to tractor parts, I usually buy from my NH dealer or an on-line source that I know supplies good quality parts.
R Wyler
01-08-2005 13:27:45
 Re: Anti sway bars in reply to Mike OH, 01-07-2005 15:13:53
Yeah I agree. I am going to NH to get them and the top link
