Shift boot
old 9-n
01-08-2005 17:00:18
Just bought a new boot. Any one heve a good trick to strech it over the tranny? Thanks Joe
dave8n
01-08-2005 21:04:10
 Re: Shift boot in reply to old 9-n, 01-08-2005 17:00:18
I did mine in about 15 seconds by warming it up and turning it inside out, slide it all the way down and then roll it on .no problems.Dave..
RedTail
01-08-2005 19:50:55
Try boiling it in water.
Russ in SoCal
01-08-2005 22:17:54
 Can't Do That. . . . in reply to RedTail, 01-08-2005 19:50:55
. . . .Wife says NO tractors in the kitchen.
R
boda65
01-08-2005 18:14:22
I just put one on mine a week ago. I did what Jerry says, plus I put it on inside out, slid it down the shifter, then just rolled it down into place. Sort of like a, well, I probably shouldn't say that here ;-) Anyhoo, it was a small struggle, but it looks good and will keep out rain water if I ever get so foolish as to leave it out in the weather again. Hope this helps.
Dan
01-08-2005 18:14:08
I used WD-40, a pair of needle nose, and my wifes help. Roll the end up over the outside, so you can roll it down into place at the base when you get it worked down there.
Good luck,
Dan
Jerry/MT
01-08-2005 17:23:17
Try some liquid soap and soak it warm water first.
old 9-n
01-09-2005 06:57:27
 Re: Shift boot in reply to Jerry/MT, 01-08-2005 17:23:17
Thanks tried some of that last night ,will get r done today , Love this board ! Always get answer and alwaws a chuckle.. Joe
old 9-n
01-09-2005 18:26:05
 Re: Shift boot in reply to old 9-n, 01-09-2005 06:57:27
Got -R -Done My son came over and the second set of hands did the trick.. Thanks Joe
