Order Ford 8N Parts Online
8n distributor
ole dirty
01-08-2005 19:09:26
is there an oil hole on the back of the distributor and if so what kind of oil should be used? resto almost complete
Fessman
01-09-2005 09:14:28
 Re: 8n distributor in reply to ole dirty, 01-08-2005 19:09:26
If it is a lube hole for the bronze bushing, then you can use SAE30 oil.
Fessman
ole dirty
01-12-2005 02:08:52
 Re: 8n distributor in reply to Fessman, 01-09-2005 09:14:28
thank you Fessman I believe it is
souNdguy
01-08-2005 21:29:14
Late 8n distribuitors had an oil cup w/ spring loaded door.. is that what you were asking for?
Soundguy
ole dirty
01-09-2005 05:53:33
 Re: 8n distributor in reply to souNdguy, 01-08-2005 21:29:14
thanks for the reply my 8 has a front mount distributor and with the distributor removed there is a small hole in theback that looks like if you put a couple drops of oil or a light grease it would lube the bushing I might be missing somthing though
