Old Warrior won't start
Ramrod
01-09-2005 09:55:19
The NAA is trying to run, even caught and spun a couple of turns after a shot of ether, but I'm not getting no satisfaction. I have rebuilt the card, it was a mess but looks fine now, and done the thumb test to confirm that #1 is firing at about the right time, and I can swing the distributor hnboth sides of #1, so I know I can get it timed correctly if it'll start. I have good fire at the plugs, and good enough compression to blow my thumb out of all the holes. I have a good 12v starter that spins the engine at a good clip, but it's hot now, so I'm having another cuppa coffee and feeling sorry fer myself. The throttle/choke linkage is disconnected, so I'm manually moving it around, but it doesn't seem to matter where they are. Any help out there?
Ramrod
Bob
01-09-2005 11:01:41
 Re: Old Warrior won't start in reply to Ramrod, 01-09-2005 09:55:19
The NAA HAS timing marks. Use a timing light while cranking and set your timing, and be done with it!
Dell (WA)
01-09-2005 10:33:09
Ramrod..... ..change yer sparkies, again. NEW and DRY, gap = 0.025..... .Dell
old
01-09-2005 10:16:24
Have do a fuel test I.E. pulled the plug out of the bottom to make sure you get a good flow of gas.
