Oil Weight
Rod
03-16-2001 18:25:41
What oil is best for the 8N?
Phil@Tex
03-17-2001 17:51:03
 Re: Oil Weight in reply to Rod, 03-16-2001 18:25:41
I tried using 10w30 here in Texas and it worked ok till it hot and then my oil pressure would drop from about 35psi to about 10psi at idle. So I went to 10w40. Now when it reaches operating temp it will hold about 20/25psi at idle. Hope this helps
Snowplow
03-17-2001 14:28:25
No such thing as best. Many will work, and some better than others in different application. Many people on this board use plain old straight 30. Many use 10w-30 (as I do). Because of the cold Maine winters I often add in a quart or 2 of 5W-30 in winter.
TimK
03-17-2001 11:54:40
For me, 10w40, any brand, as long as it has the api starburst logo on the side of the bottle.
chuck
03-17-2001 03:42:31
Rod, I had my engine professionally rebuilt about 8 years ago. I tried 10W30 the first oil fill but was not happy with the low oil pressure when working in the summer. Since the first oil change I have used straight 30W Pennzoil. It has more oil pressure when hot and starts without a hitch down in the 0F temperatures we experience here on the East Coast in the dead of winter. (12v/electronic ignition)
chuck 436244
JimNC
03-16-2001 19:13:19
10W30 is fine
