Old Warrior Wakes Up
Ramrod
01-09-2005 14:41:26
The NAA finally fired up and ran. It took some ether and several spark plug changes after running them through a propane torch to dry 'em out. It ran for a good long time, but wouldn't hold an idle. I still have a flooding problem, what about the presets and stuff on a fresh rebuilt carb? I set the float using a 1/4" bolt space between the gasket and floats, and turned the two adjustments down tight and backed out 1 1/4 turns.
What else should I look for?
Ramrod
billOH
01-09-2005 15:14:52
 Re: Old Warrior Wakes Up in reply to Ramrod, 01-09-2005 14:41:26
Wow, everybody's problems are being solved today. There must be some good 8N karma in the air. :)
Jeb2N
01-09-2005 14:58:00
If it's anything like the 2N/8N carbs, that 1-1/4 turn is just a generic place to start to get the engine to crank the first time after a rebuild. Once it's up and running, you tweak the settings to get it to idle and rev up properly. None of them ever really stay at 1-1/4 turns...just a refernce point to start from.
