750# engine stand A-OK for N!!!
rasputen
01-09-2005 20:47:43
I can't find the exact weight for the N(gine) but I did find some VERY reasuring info:
Chrysler 331 Hemi 1955 --->745#
I think the 4 cyl N-gine "may" weigh less than a 1955 castiron Hemi.
Matt Little
01-10-2005 10:48:58
 Re: 750# engine stand A-OK for N!!! in reply to rasputen, 01-09-2005 20:47:43
heres a intresting link for engine wieghts :>Link
but>Link it doesnt cover tractor stuff tho :(
rasputen
01-10-2005 17:03:45
 Re: 750# engine stand A-OK for N!!! in reply to Matt Little, 01-10-2005 10:48:58
That's the exact link I used.
Matt Little
01-10-2005 17:10:09
 Re: 750# engine stand A-OK for N!!! in reply to rasputen, 01-10-2005 17:03:45
Nice ! Ive had that link for years - to bad it doesnt have more info tho
don b
01-10-2005 07:08:00
I think the complete engine weighs around 425#,and just the block weighs about 100#, if my memory is working today. don b
TIMW(PA)
01-10-2005 06:01:36
third party image
Yep. Harbor freight cheapy stand 750# capacity. Like Dan said i replaced as many bolts as a could with Grd 8s from TSC. Good luck
billOH
01-10-2005 13:18:04
 Re: 750# engine stand A-OK for N!!! in reply to TIMW(PA), 01-10-2005 06:01:36
Tim, if ain't too personal: how much did you pay for that stand? Could you also use it to jack up the rear end, let's say to adjust the brakes?
Dan
01-10-2005 04:54:46
I am not 100% sure anout the 9N/2N/8N engine, because the oil pan is very heavy, but the 750 lb. engine stand holds my NAA engine fully loaded with no problems. I replaced the bolts that came with mine with some grade 5 bolts. I wanted grade 8, but could not find the 7/16" size grade 8 bolts at the TSC store.
I have seen pics of a 9N engine with the oil pan installed on a 750 lb. stand before.
HTH,
Dan
Tim...OK
01-10-2005 06:27:08
 Re: 750# engine stand A-OK for N!!! in reply to Dan, 01-10-2005 04:54:46
My cheapey engine stand dropped a 454 Chevy one time cause of junk bolts,upgraded to good bolts,have had to problems since..Don't think an N engine would be a problem..
Tim
