carb question for experts
Rusty8N
01-10-2005 09:19:45
Front mount 8N, M-S carb...I had flow from gas line but no flow from bottom of carb...as recommended here previously, I removed and inspected elbow screen...all clean...removed carb and had a look...appears that needle valve on top of float "sticks", i.e. won't fall when float falls...sometimes falls with sharp rap,but mostly does not, even after cleaning...see that you can order a new needle valve and its gasket for 3$...is my problem as simple as that? is it harder than it appears to do this replacement?? should I do other stuff to the car while it is apart??? Thanks for sharing your expereince...Rusty
old
01-10-2005 10:47:48
 Re: carb question for experts in reply to Rusty8N, 01-10-2005 09:19:45
I'd put a complete kit in it when you have it apart. The kit will also have the needle seat in it
Dan
01-10-2005 10:45:41
Yep, it really is that simple. The newer neoprene needle tips are much more prone to sticking. Use a chisle or a thick gasket scraper to remove the brass needle seat, you want to ensure you go through both slots fully, or you will just strip the slot - and then it will be a dog to remove. Do a full rebuild while you are in there. I would just check my jets and try to get them clean rather than replacement, because they usually get torn up when you try to remove them.
Good luck,
Dan
