resistor on switch
agriffin
01-11-2005 18:24:57
i am having trouble getting my 8-n to crank and was wondering if anyone could tell me if the resistor on the switch is important in cranking ---thanks
roger '40 9n
01-12-2005 07:05:38
 Re: resistor on switch in reply to agriffin, 01-11-2005 18:24:57
The resistor has no effect on making your
starter motor crank your engine. It WILL
affect your sparkies and make the engine hard to start iffn it is not working properly.
Roger in Michigan.
Rick S.Mich. 8n
01-20-2005 16:50:35
 Re: resistor on switch in reply to roger '40 9n, 01-12-2005 07:05:38
Could you please explain a little more about the function of this resistor and how it would go bad? I am gathering, after reading a bunch of archives this may be my poor starting issue. Thanks Rick
Dell (WA)
01-11-2005 19:24:47
Griffin..... ....yes, it is important for your sparkies, why do you ask?. Remember the 6 volt MANTRA: " keep'em clean, bright, and tight"..... ...respectfully, Dell
