Rod, "New stronger springs" installed when you rebuild the engine may help...most noteably if the old ones are worn out or broken, but as Zane has pointed out, it is very likely a combination of factors, not just valve springs that causes the engine to need attention. We've been running a 52 8-N for the last 15 years. Over that time span it has gone from a good strong tractor, to one that is very hard to start, and lacking in power. It is used mostly for general grading and landscaping, so the (gradual) power loss has been acceptable. Last fall, after having to pull it to start when needed, the decision was made to tear it down over the winter. The first thing we found, was badly burned exhaust valves on # 2-3-and 4 (#1 was ok). Large chunks of the valves were burned away...amazing it would run at all! Probably a waste of time, but after installing the new valve assemblies (all of them) we're going to reinstall the head temporarily to check compression levels. Had 90# on #1 but because of the burnt valves the others were rather low...20# More to come. Rob
