Rear Axle Bearing Shims ?
Roy n Ky
01-12-2005 17:40:57
Hello All ,I am replacing bearings and seals on my 52 8n. Ordered a shim ( 9n 4130 )was expecting a steel part but I recived a gasket sytle one. Is this the current replacement type part ? Also would apreshe8t :) any pointers or time savers .p.s. I have read F4 mannual and studied Jonh Smiths site . Thanks for your time ,Roy
John (TR)
01-13-2005 09:46:12
 Re: Rear Axle Bearing Shims ? in reply to Roy n Ky, 01-12-2005 17:40:57
I did a 2n 2years ago with mostly paper shims. No leaks to date, works fine. I just did my 48, used all the metal except for 1 that was bent too much that I replaced with 1 or 2 paper till I got the clearence right. Worked fine also. Used RTV Blue silicon on both tractors, no leaks, brakes are a nice option!
don b
01-13-2005 07:03:35
 Re: 9N 9130 IS the shim in reply to Russ in SoCal, 01-12-2005 21:53:24
The metal shims are 4229,paper 4130.Metal shims are about 5.00 ea. and paper is .50.Paper shims work just as good or better. don b
Russ in SoCal
01-12-2005 19:47:49
Roy,
The Master Parts Catalog does not list a P/N 9N 4130. It does list P/N 8N 4229D, E and F for .010", .017" and .022" shims. Last ones I saw were metal. As far a pointers and time savers, John has it pretty well down to basics. I saved so much time the first time I had mine apart, I had (time) to do it again. 8 ^ )
Russ
rasputen
01-12-2005 18:52:44
I had my new hubs for a year before I got around toit.
It's not as bad as it seems, just kept adding shims & adding shims till the other wheel started to reverse.
It's GREAT to have brakes!!!!(for the first time)
rasputen
01-12-2005 19:00:11
 Re: Rear Axle Bearing Shims ? in reply to rasputen, 01-12-2005 18:52:44
Oh yeah....paper is fine & less leaks.
I did reuse my 1 metal inbetween paper shims.
Coat all sides with LIGHT coat of selant of your choice, I used Blue Permatex.
Roy n Ky
01-13-2005 18:19:42
 Re: Rear Axle Bearing Shims ? in reply to rasputen, 01-12-2005 19:00:11
Thanks a million guys , I knew youall would come through . Keep the rubber side down , Roy
