OK, lets clear this up. I am LOOKING for a reason, any reason to do a Full rebuild in a restoration program. I need to do it before spring mowing season. I have my garage cleaned up (monumental event). I know my compression readings by heart 1=90, 2=75 3=90 4=90. Slight improvement wet. Split valve guides swap holes (almost). I already knew it had sloppy guides & stems. I did a mild valve lap & replaced 1 or 2 valves in 2001 while recuperating from back surgery. This tractor runs awsome, great power & leaks more oil than it burns. Bearings make no excessive noise & will plow till the muffler gets red. I don't NEED a rebuild. That said , I want to get it done now cause the time is right. I want to get rid of the "sputter". No way I am going to do a valve job without a complete rebuild, BTW I will replace the sleeves & pistons, turn the crank & maybe oil pump & line bore. I will check on the valve seats, & possibly have them replaced if ANY questions. The vacuum gauge vibrates like it is posessed at idle, at high idle (~600-700) it shows 2-3 inches drop when the sputtering is going on. I do not recomend anyone else do a rebuild if their tractor misses a tiny "sputtering" miss like mine. But I am at the point in a FULL restoration on a working tractor where this was enought evidence for ME to do it before March. I have another tractor to use but I am addicted to this 8N, it is my ZEN tractor! This is my main hobby in the winter,tweaking,tuning,diagnosing,& deciding how far I want to go. Got an engine stand yesterday before I bought the vacuum gauge, see where I'm comming from??
