Rear axle torque wrench
hvw
01-14-2005 09:53:12
I ran across a torque wrench today rated at 600 ft/lbs. Military surplus from the Air Force. About four feet long with 3/4 inch drive. Perfect for that rear axle nut that causes so much concern. I didn't ask how much it was because it looked like it cost more than an 8N. I guess I'll keep bouncing up and down on a cheater bar unless I hit the lottery.
Johnski
01-14-2005 17:03:42
 Re: Rear axle torque wrench in reply to hvw, 01-14-2005 09:53:12
I"ll let you in on a professional secret. There is only one torque setting to be applied all fasteners. "Torque to 3/4 turn past stripped and back off 1 full turn". No Torque Wrench Needed.
(Courtesy of Acme-Universal/Fitzall Co.) 8>)
Chippewa Al
01-14-2005 10:35:37
I found that the local A-1 Rental Shop has one!!
Or you can buy one for under $400 at:
Link
Al
NEsota
01-14-2005 12:24:11
 Re: Rear axle torque wrench in reply to Chippewa Al, 01-14-2005 10:35:37
Perhaps, if you hang 100 pounds of weight on a bar at a point four feet from the center of the axle, you will come close. Tell me please, the easiest way spell check my posts.
Russ in SoCal
01-14-2005 13:11:37
 Hears howe in reply to NEsota, 01-14-2005 12:24:11
Eye halve a spelling chequer, It came with my pea sea. It plainly marques four my revue, Miss steaks eye kin not sea.
Eye strike a key and type a word, And weight four it two say. Weather eye am rong oar rite, It shows me strait a weigh.
As soon as a mis steak is maid, It nose bee fore two long. And eye can put the error rite Its rare lea ever rong.
Eye halve run this poem thru it, I am shore your pleased to no. Its letter purfect awl the weigh, My chequer tolled me sew.
SteveB(wi)
01-14-2005 13:23:17
 Re: Hears howe in reply to Russ in SoCal, 01-14-2005 13:11:37
That's Grate! I love it.
Crabby old coot
01-14-2005 15:31:15
 Re: Hears howe in reply to SteveB(wi), 01-14-2005 13:23:17
i youse a dickshunery my selve
aint never made but one mis steak in my live and that was in inglishe butt i seen that one in tyme and taken it back
