OIL PRESSURE
BOB
03-17-2001 19:18:32
GOT MY 8N 6CYL FUNK RUNNING STARTED WITH THIRTY PUNDS OF PRESSURE WHEN WARM AT IDLE DOWN TO ABOUT 5 OR LESS. ONE DOES IT HAVE A OIL PRESSURE RELEIF VALVE OR AM I IN FOR A REBUILD ENGINE DOES NOT SMOKE OUT THE EXHAUST BUT DOES EMIT A STRONG ODOR OUT THE BLOW BYE TUBE UNDER THE MANIFOLD , I DONT KNOW IF THESE ARE LOW PRESSURE ENGINES OR NOT ANY INFO WOULD BE GREATLY USED THANKS
CRS in AL.
03-18-2001 07:13:10
 Re: OIL PRESSURE in reply to BOB, 03-17-2001 19:18:32
Yes Sirrea BOB , that flathead 6 cyl. Ford motor does have a relief valve in the oil pump. It should be idling cold around 20 to 25lbs. I would strongly urge that you drop oil pan ,take off oil pump and replace the valve or either oil pump. That low pressure is not good and will cause damage..
Al English
03-18-2001 09:48:36
 Re: Re: OIL PRESSURE in reply to CRS in AL., 03-18-2001 07:13:10
Hi CRS, Changing the relief valve and/or pump can't hurt anything. But, if the oil pressure is low due to loose clearances in the engine, replacing these items will not correct the problem. With very few exceptions, an engines oil pump will still be in usable condition when the rest of engine it completely worn out. This is an old engine, and yes the pump may have been re-used through several rebuilds, but I'd be looking at bearings if I were taking the pan off...Al English
Ron
03-18-2001 10:29:13
 Re: Re: Re: OIL PRESSURE in reply to Al English, 03-18-2001 09:48:36
go here
http://www.melling.com
CRS in AL
03-19-2001 18:42:37
 Re: Re: Re: Re: OIL PRESSURE in reply to Ron, 03-18-2001 10:29:13
Hi AL, Your are right, I went back and re-read what Bob had ask. I mis read his statement.Excuse Me. I thought it said he had rebuilt it. But after reading again it say (OR AM I IN FOR REBUILDING)?
Hay Bob, You might try compression test before going any further.
Al English
03-18-2001 06:56:29
Hi BOB, I am not familiar with your engine, but yes, all engines have a pressure relief(regulator) valve somewhere in the oil system. The 5 pounds of pressure at idle is low. But if it can maintain 10 PSI at 1000 RPM, 20 PSI at 2000 RPM, etc, when hot, it isn't going to hurt itself. You didn't say what weight oil you are using, but if the engine is worn, heavier oil might get you by for quite a while. If you need heavier oil, use heavier oil. Don't use STP or similar products, in spite of what is generally believed they are poor lubricants. Good luck...Al English
