What are the two little caps on the distributor
Rick S.Mich. 8n
01-17-2005 17:36:20
I'm just curious. What are the two little caps with 4 holes in them on the front mount distributor? Thanks
Lugnut
01-17-2005 18:49:08
 Re: What are the two little caps on the distributo in reply to Rick S.Mich. 8n, 01-17-2005 17:36:20
Rick, those little "caps" are vents to dissipate moisture in the distributor. Lugnut
Rick S.Mich. 8n
01-17-2005 19:22:42
 Re: What are the two little caps on the distributo in reply to Lugnut, 01-17-2005 18:49:08
Should they be open or is there a filter media of some sort in them? Or should I clean them out? Most likley grease and dust if its not a filter. Thanks for the reply.
Rick.
Lugnut
01-17-2005 19:35:37
 Re: What are the two little caps on the distributo in reply to Rick S.Mich. 8n, 01-17-2005 19:22:42
Rick, not sure--never had to clean mine. There is a filter media, I believe. Maybe someone smarter than me will help out. Have you tried blowing them out (well, not all the way out)? Lug
Jeb2N
01-17-2005 19:34:07
Mine had a fine brass mesh across them. At least I think it was brass. Could have been some other metal. They should be open. This helps to prevent the distributor from being "water logged". Ever notice how your N might not start after washing it? That's why. Moisture in the distributor is a bad thing!
jwm
01-17-2005 18:17:35
The front mount distributor has a distributor cap with four holes for the spark plug wires. I have never seen or heard of one with two caps. If yours has two caps please post a picture. James
Rick S.Mich. 8n
01-17-2005 18:27:47
 Re: What are the two little caps on the distributo in reply to jwm, 01-17-2005 18:17:35
Not the cap itself. The distributor. It has two "caps" that have four smaller holes in each, one on the bottom and one on the upper right side looking at the front of the distibutor. The "caps" are over a hole in the distributor.Perhaps for ventilation? I am just curious as I just changed my points, was looking at the distributor.
