Order Ford 9N Parts Online
9N won't plow after 15 Minutes
PF
01-17-2005 17:43:07
I start her up. Warm her up. Take her down the driveway a few swipes, then she just kind of fizzles out. Stays idleing for a while but then dies. I let her sit for 10 minutes, then the same thing happens again. New plugs last year, change oil, cleaned carb last year. Any advice is greatly appreciated as it is only January.
Dell (WA)
01-17-2005 18:08:15
 Re: 9N won't plow after 15 Minutes in reply to PF, 01-17-2005 17:43:07
PF..... ...there are 4 common runtime frontmount engine problems.
1) runs for about 1 minute and quits. BAD condensor; not your stated problem
2) runs for about 5 minutes and quits. CLOGGED fuel filters; not yer stated problems
3) runs for about 1 hr and quits; restarts the next morning; BAD squarecan ignition coil; not your stated problem
4) runs for about 15 mins and quits; restarts after about 30 mins; sound like yer problem? BAD IGNITION SWITCH GUTTZ you doubt? take a jumper wire with alligator clippies and jump yer ignition switch at yer "T" terminalboard underneath yer ammeter. Unfortunately, N-Ignition switches are not as robust as we'd like'm to be. ..... ....Dell
12volt Mel
01-18-2005 03:49:18
 Re: 9N won't plow after 15 Minutes in reply to Dell (WA), 01-17-2005 18:08:15
Hey Dell, you are on the bad switch deal, had to change mine twice. You didn't say if you ever had to change your switch and since I flunked mindreading just ask my wife of 35 years I don't know if you found a switch better and stronger than oem ?
Grin
Mel
TIMW(PA)
01-18-2005 05:48:57
 yes he did! 3 in one summer! in reply to 12volt Mel , 01-18-2005 03:49:18
You either haven't been paying attention in class or you haven't been around long enough...Grin....He had three of them go bad in one summer and he finally replace it with a water proof marine swicth.
Do I get an A???? <8^)
Dell (WA)
01-18-2005 06:21:06
 Re: yes he did! 3 in one summer! in reply to TIMW(PA), 01-18-2005 05:48:57
Mel..... ...Tim is right. I replaced my ignition switch 3-times in one summer. Last time I used a 25A marine grade waterproof toggle switch. Who needs a key, eh? (which BTW, the same ignition key fits ALL Ford tractor ignition locks, some security eh?)..... ...Dell
PF
01-18-2005 18:40:48
 Yes, but back to my tractor in reply to Dell (WA), 01-18-2005 06:21:06
You really mean that an ignition switch can work, then not work, then work again?
If your sure of this. I'll change the toggle switch that's on there now.
Thanks for your help.
PF
