Order Ford 8N Parts Online
8n head gasket
8nNewbie
01-18-2005 05:56:26
Hi all,I am putting the head back on the 48 with a new gasket.According to previous posts it is recommended to paint the gasket and head w/ rustoleum before installation.What is the purpose,and I dont add any other sort of sealant?As always Thanks!!
Tim...OK
01-18-2005 06:54:18
 Re: 8n head gasket in reply to 8nNewbie, 01-18-2005 05:56:26
I would say the aluminum paint is what he had in mind,I use copper coat on mine,remember to re-torque after 20-30 minutes of run-time or you'll get to replace it again..
Tim
Bruce (VA)
01-18-2005 06:35:51
I think it was Rustoleum aluminum paint. Might be a good idea if you have had problems w/ leaks. I install mine dry.
philm
01-18-2005 06:20:17
i don't know the purpose of rustoleum on the head gasket. probably won't hurt.
i install mine dry with no problems.
dave8n
01-18-2005 08:12:26
 Re: 8n head gasket in reply to philm, 01-18-2005 06:20:17
I've never put anything on a head gasket others do to help find leaks if you have to remove it again...Dave.
