Rear axle
RedTail
01-18-2005 09:52:53
Well, after I got the brakes opened up it was all full of oil in the drum. So it looks like I have to replace the seals. How can I tell if the bearing needs replacement? I have been reading the archives and just hoping to go with a sure seal.
BTW the pads are not worn but full of oil. Can they be cleaned up or better to just replace them??
TX
E. Ray
01-18-2005 12:39:42
 Re: Rear axle in reply to RedTail, 01-18-2005 09:52:53
From previous posts I have read, you can burn the oil out of your brake shoes with torch. I tried it on a friends 600 w/out much luck. Maybe I did not burn it long enough..... ...E. Ray
Russ in SoCal
01-18-2005 13:28:34
 Re: Rear axle in reply to E. Ray, 01-18-2005 12:39:42
E Ray,
Not a matter of "burning" the oil. Use the heat in between the spraying and wiping to draw the oil up out of the shoe. CAUTION: Brake cleaner is flammable.
Russ
old
01-18-2005 11:17:59
A lot of times the reason a seal goes bad is because the bearings get loose/bad.
uh . . . Dell (WA)
01-18-2005 11:36:50
 Re: Rear axle in reply to old, 01-18-2005 11:17:59
RedTail..... ....the primary reason (besides leaky axle seal) that yer 2N's 17" brakeshoes are greezy is OVERFILL of the hydro-tranny. We recommend as a double-check, remove the bottom bolt of your 6" dipstick plate and allow all EXCESS hydro-tranny oil to drain out overnite. That results in a hydro-tranny oillevel that minimizes leaks out the rearaxle trumpet mouth (even iff'n you already have bad seals) 'Course the right thing to do is to replace yer 2N's axleseals with "Sure-Seals". (and keep the hydro-tranny oillevel set right..... .Dell
Red Tail
01-18-2005 12:41:48
 Re: Rear axle in reply to uh . . . Dell (WA), 01-18-2005 11:36:50
Thanks Dell, the oil level was below the dipstick, the previous owner didnt take too good care of it.
Can I clean up those brakes after I fix the leak?
Russ in SoCal
01-18-2005 13:24:40
 Re: Rear axle in reply to Red Tail, 01-18-2005 12:41:48
Redtail,
Yes, you can clean the brake shoes. Takes some time and effort. Spray with brake cleaner, wipe off, spray, wipe, spray, wipe,spraywipespraywipespraywipe. . . . . . .
old
01-18-2005 11:55:56
Yes Dell over full can be the problem also but in my years of working on things car, trucks, and tractors bearing can are are to most common problem with bad seals.
