Order Ford 8N Parts Online
8N Hydraulic Blues
OKcity8n
03-18-2001 08:47:23
I have hang time on my hydraulics that will make many drool. I had a chance to time it yesterday while working on the starting problem. I put my VERY heavy box blade on, lifted it to the top, and let it sit. Two hours later, it was still over halfway up. At 4 hours, it was on the ground. Sooo, what's the problem? It will not lift unless I place the draft control in the draft position regardless of the position control being at the top. It also lifts very slowly this way. If I hold the draft lever to about halfway between the two positions, the lift works very fast. I think I remember seeing this problem and solution in the archives(probably from Zane), but was not able to find it this time. Any hints? 8N, 1949(not 48 as previously stated)12 volt.
