Order Ford 9N Parts Online
WANTED 9n PTO belt pulley
9n8801
01-20-2005 16:22:14
I need to buy a PTO belt pulley for a 9N with a
1 3/8 PTO shaft.
Does anyone know where I can buy one at a fair price? Thanks.
Leon at NW Fl.
ZANE
01-21-2005 09:36:06
 Re: WANTED 9n PTO belt pulley in reply to 9n8801, 01-20-2005 16:22:14
Ford did supply an adapter extension so that the 1-1/8 belt pulley could be used with the 1-3/8 shaft. Required an PTO adapter to go with it. Long bolts too.
Zane
Dean
01-21-2005 07:01:24
Not sure if they are still available but as recently as 10 years ago one could get an adapter designed to space the pulley away from the tractor enough so that the commonly available 1-1/8 to 1-3/8 PTO adapter could be used between the pulley and the PTO shaft. I have both of these on my pulley as both of my Fords have the larger PTO shaft.
Dean
timw(pa)
01-21-2005 05:43:32
Theres one on ebay right now. It dosn't stae the shaft size though...HTH Tim
George Willer
01-20-2005 18:22:53
I have one I'll part with. All 3 of my Fords are otherwise occupied, so I have no way to use it.
George Willer
lr9936
01-21-2005 10:24:51
 Re: WANTED 9n PTO belt pulley in reply to George Willer, 01-20-2005 18:22:53
Mr.Willer,IS the pulley A 1 7/8 or 1 3/8 ? Also how much do you want for it,is it in good cond,and how much does it weigh and where are you located? thanks Leon in NW Fl.
George Willer
01-21-2005 14:07:44
 Re: WANTED 9n PTO belt pulley in reply to lr9936, 01-21-2005 10:24:51
My health keeps me from checking for sure, but I think it is the early 1 1/8 size. It has the paper pulley and it should be in good condition. I think it is workt at least $50.
George
Mike S
01-20-2005 16:55:58
They originally came only with the 1 1/8" but I understand that Ford did come out with a replacement input for the 1 3/8" shaft. Just a simple change out. I have seen both at some tractor swap meets. you just need to look around for one.
Steve(OR)
01-20-2005 16:25:38
I believe belt pulleys for N tractors have only ever been made for 1 1/8 shafts. Someone will correct me if I'm wrong.
9n141
01-20-2005 18:49:20
 Re: WANTED 9n PTO belt pulley in reply to Steve(OR), 01-20-2005 16:25:38
I agre. Look for a pulley for a 601 or 801 or later models with larger shaft. If org. doesn't matter MF had pulley with large shaft. BURT.
