Order Ford 8N Parts Online
8N Not turning over
rzeigler
01-23-2005 19:23:16
I have a 51 8N that was running on thursday and we got about 8" of snow and the temp dropped so I figured the old girl was going to be tough to start but I'm confused. It started to crank a few times and then nothing no clicking nothing. Here are the specs. 6 volt system new cap,rotor,coil,points,condensor,ignition switch, push button, celonoid(sp?), ingition switch , voltage regulator, and wiring. I have checked all connections to make sure tight and shiny but I am at alost and need any help I can get.
Barnstormer
01-23-2005 19:34:49
 Re: 8N Not turning over in reply to rzeigler, 01-23-2005 19:23:16
Try a jumper from the batery directly to the starter. If that works I would suspect that the starter button is not providing a complete circuit. The other thing can still be a battery cable connection. Try them again.
Russ in SoCal
01-23-2005 22:39:12
 Re: 8N Not turning over in reply to Barnstormer, 01-23-2005 19:34:49
Zig,
What BSer, I mean Barnstormer, said and... If you have lights, turn them on an hit the starter button. If the lights go out, it indicates a puny battery. (Pologies in advance Barnstormer 8 ^ ) )
Russ
Barnstormer
01-24-2005 08:26:17
 Re: 8N Not turning over in reply to Russ in SoCal, 01-23-2005 22:39:12
No offense taken. Good chuckle.
