Fill Tubeless Tires??
Phill B
01-24-2005 21:13:14
I have another tractor that has some tubless rims/tires on
the rear and want to fill them to reduce tire slip. Can this be done reliably? I can"t think of a reason I shouldn"t, assuming there is enough antifreeze to manage the rust potential. Am I missing something? Any insight would be appreciated.
Phil B.
Dean
01-25-2005 06:20:03
 Re: Fill Tubeless Tires?? in reply to Phill B, 01-24-2005 21:13:14
Smaller lawnmower or compact tractor tubless tires are often filled with antifreeze/water for ballast without ill effect. It is relatively easy to do on such small tires by laying the tire/wheel on its side and breaking only the top bead. Just pour the antifreeze in. You may need another set of hands and/or an inflatable bead expander to seat the bead so as to air the tire. Obviously you would not want to use calcium chloride.
Dean
souNdguy
01-25-2005 06:19:24
Like Bob mentioned.. you can 'go tube' like Bob says.. or use a correct antifreeze product that will help prevent corrosion.. however.. don't use CACL. Rimguard might even be an option (beetjuice).
Soundguy
Bob
01-24-2005 21:31:42
Unless they're some really odd size, it wouldn't cost too much to put tubes in them, and keep the ballast out of contact with the rim.
Phill B.
01-25-2005 10:48:18
 Re: Fill Tubeless Tires?? in reply to Bob, 01-24-2005 21:31:42
Thanks for the input guys. The tires and weights are on and I'm looking for the quick solution. I'll put tubes in next time I have to change tires. Thanks again for the info.
Phil B.
gahorN
01-26-2005 10:28:09
 Re: Fill Tubeless Tires?? in reply to Phill B., 01-25-2005 10:48:18
You don't have to completely change tires to insert tubes. Just deflate, collapse one bead inward/away from the rim and insert the tube. Use a string and/or cable with a stem-puller to pull the tube stem thru the hole, and fill 'er up!
