NAA - New Sheet Metal Installation
Ramrod
01-25-2005 11:30:11
It is time to start thinking about installing the new sheet metal on the Old Warrior. I have a new kit, all the pieces. What is the correct/best way to install this stuff? Assemble and install one piece, or piecemeal? Paint before or after install?
Thanks,
Ramrod
tp
01-25-2005 13:52:52
 Re: NAA - New Sheet Metal Installation in reply to Ramrod, 01-25-2005 11:30:11
I painted each individual part so that all the seams, nooks, and crannies received their fair share of paint. I then assembled the entire assembly less the hinged lid and carefully attached bottoms of the doglegs to frame with the panel end tied up from the ceiling. The whole assy will hinge back as you let it down from the ceiling. Another able body is quite helpfull but not absolutely necessary. Once attached to the gage panel the hinged lid can be fitted and adjusted. Touch up any damage and fasteners with a fine bristle brush. I'm sure there is a better way, but I was happy with the results. Good luck.
Mike S
01-25-2005 12:21:39
I put all my back together this way. The side pieces to the hood and doglegs, nosecone and bottom first, installed that and then set in the dash and bolted it up and then installed the hood itself and then finally the grill. I guess you could do it with more pieces together, but I did not have any help so needed to keep the pieces as light as possible.
Dan
01-25-2005 12:04:48
What did you do with the old sheet metal? I am in need of the left side dog leg...
Dan
ramrod
01-25-2005 13:08:34
 Re: NAA - New Sheet Metal Installation in reply to Dan, 01-25-2005 12:04:48
It's not NAA sheet metal, 600 I think. I'll compare to my new doglegs and let you know, but I'm sure they're way too short.
Ramrod
