Battery Blanket/Cold Weather starting
Sal8n
01-27-2005 07:14:35
Never saw one and don't really now much about them.
My understanding is that it is a bag or sleeve that goes around the batter and you plug it in to keep it warm. Kind of like a heating pad.
Sounds like a good idea for January in upstate NY.
How helpful are they if your equipment is in good shape?
Would a dipstick heater be a good idea as well? I have heard they can get too warm though and should be put on timers.
Any general tips on cold weather starting?
TY
Sal
Alaska Jon
01-27-2005 11:30:03
 Re: Battery Blanket/Cold Weather starting in reply to Sal8n, 01-27-2005 07:14:35
They also make a heating unit that sits under the battery. It plugs in, and the heat rises into the battery, warming it much more efficiently than the "wrap around" blankets. -Jon
Dell (WA)
01-27-2005 09:08:11
Sal..... ...yes, warm battery chemical reaction is ALWAYS STRONGER for better starting. And yes the battery warmer is a good thing.
Back in the 40's before the days of the die-hard, my Father would remove the battery of our hard-to-start wornout Plymouth 6-cyl flathead, and keep it warm in the house when temperatures were predicted to be BELOW ZERO in our Colorado mountain mining town (now a semi-famous ski resort) Always started while I scraped the FROST off the windows. Our next door neighbour would fill his drained-out radiator with hotwater from teakettle (too cheap to buy anti-freeze) and as a final flourish, pour the last of the HOTWATER over the carb intake manifold..... .....the frostbite Dell
danct
01-27-2005 08:51:32
Sal i use two magnetic heaters from Napa,they are part #745-1073,they give 200 watts of heat ,i put one under the hydraulic pump section and one in the oil pan area ,seems to help a lot good luck
Danny
North Bay, Canada
01-27-2005 08:09:12
Sal
You're right about the battery blanket - it's really a heating pad you plug in.
I have a '52 Ferguson with a heater on the coolant hose. Below freezing, it won't crank enough to start if it's not plugged in. However, I have started it at -25 deg. C (-15 deg. F) when it's plugged in, and it starts immediately and runs without choke. I was told to keep the clutch depressed until it warms up because you can hear the engine labuor a bit when you try to let the clutch out.
Last weekend, I tried to start it at about -20 C (it hadn't ben plugged in) and I could tell from the first few cranks that it wasn't going to happen. So I plugged it in & waited about 1/2 an hour. It then started, but I needed the choke to keep it running for the first couple of minutes. It really opened my eyes to the effectiveness of the heater.
Gary
Ramrod
01-27-2005 07:59:43
When we lived up north, I outfitted my diesel with battery warmers that were just a rubber pad that the battery sat on. Wired the two of them together with the block heater and out to a cord, that old truck started up and had a warm heater even on the coldest mornings. They were cheap too!
Ramrod
Dean
01-27-2005 07:43:23
Anything that helps to keep a lead acid battery warmer will improve its performance in cold weather. As a result you will be able to crank somewhat faster and longer, all else being equal. Heaters that warm the engine oil and/or coolant will help cold weather starting as well but for different reasons.
One commonly overlooked cold weather starting tip is to always hold the clutch disengaged when cranking so that the starter does not need to overcome the load resulting from turning the transmission input shaft and cluster gear in the cold transmission oil. On Ns not doing this and leaving the PTO engaged would also load the starter with the load required to turn the hydraulic pump.
Dean
