I plowed snow for years with my 8N before I got a Bobcat. Here's what I suggest: -- You might get away without chains if you're on flat ground, but if you're plowing snow in hill country, chains are a must. I just used ladder chains, which, with the occasional use of a brake pedal, and plowing mostly downhill or on flat ground worked fine. -- For long runs on driveway-width areas, use the blade facing forward, slanting a bit to one side. I used to do my gravel driveway with three passes, first down the center with the blade slanted to the right, then down the right side with blade slanted same, then down the left side with the blade slanted to the left. Since my driveway is steep downhill, I made all the passes from the top down. -- For shorter, wider spaces, like parking areas, use the blade reversed and not slanted. Good for shoving snow into piles, too. Plowing backwards with the blade reversed works a lot better if you have stabilizers on the hitch, otherwise the blade will sometimes shift from side to side. -- Loader is nice for picking up snow and moving it around, especially after several heavy snowfalls where sometimes there's no more empty space to shove it into with a blade, but a narrow bucket, especially since you can't slant it to one side or the other, will make slow going of routine plowing. A blade is faster. -- Gravel isn't too much of a problem once the ground is frozen, especially since the 8N hitch has no down pressure, but those first few snowfalls can be a problem. Probably the best solution is to fabricate some bolt-on shoes for the blade that you can use when the ground is soft. Being lazy, I'd turn the blade around and plow forward with the blade backwards. Worked fine if the snow wasn't too deep, and didn't move nearly as much gravel. Besides, if you think gravel is a problem with the blade on the 8N, just try plowing snow with the bucket on a Bobcat!
