Order Ford 8N Parts Online
8N hydrolics will not go down
Paul D. Metzger
03-19-2001 11:23:38
My 1951 8N hydrolics will not drop once raised until leakage bleeds the ram. If I let the ram go all the way up, I can not lower the hydrolic lever(too much pressure) unless I disengage the PTO and let the system bleed off some. I have disassembled the pump, ram and cleaned everything and all looks good. Where do I go from here?
Steve IA
03-19-2001 13:22:26
 Re: 8N hydrolics will not go down in reply to Paul D. Metzger, 03-19-2001 11:23:38
Try this. Remove the inspection plate from the right side. Inspect the control arm that connects the quadrant with the control valves below fluid level. It should be straight or nearly straight. If it is bowed, you may not have enough play to activate the exhaust control valve. Try moving the arm by hand and see if you can get valve open and hitch to drop. If not bowed, then for some reason you are not opening the exhaust valve. Perhaps a quadrant adjustment as described in the manual will help. HTH Steve 8N 169302
