Clutch question
ODIE 48 8N
03-19-2001 16:34:37
I have a 48 8N and when it was colder out the clutch would disengage the pto right away. Now when I have been using it it doesnt disengage right away it takes about a minute even after warming up for several minutes. But after I get it in to gear and work it awhile it works pretty good till I let it set a couple of minutes then it does it again. Thanks in advance.
ZANE
03-19-2001 17:33:30
 Re: clutch question in reply to ODIE 48 8N, 03-19-2001 16:34:37
Oil residue on the clutch disc.The clutch is sticking because it has a film of oil on the disc the plate and the flywheel. It acts just like when you have a wheel cylinder or grease seal leaking on drum brakes on a vehicle and it makes the wheel grab and slide sometimes. "For the old guys who know what drum brakes were".
You can give it a temporary fix sometimes by removing the bolts from the starter and pulling it out far enough to dump into the clutch housing about a cup or more of talcom powder. The powder will act just like oil dry does when you spill oil on the floor. Be sure and use real talcom powder and not the newer corn starch stuff that is used on baby bottoms.
Don't be afraid to put to much in the clutch housing. The more the merrier when it comes to drying out the clutch. The air movement caused by the clutch parts revolving around in the housing will pick up the talcom and distribute it between the parts.
