wagner loader front mounting bracket
1941-9NTom
01-29-2005 18:05:31
I just got a wagner loader and no front bracket for mounting it. So now I'm pulling hair out trying to find one for 1941 9N. Please help me if you can!
Phill B.
01-30-2005 17:09:46
 I have one! - wagner loader front mounting bracket in reply to 1941-9NTom, 01-29-2005 18:05:31
Tom,
I just happen to have one. It is a long story on how I finally found this one but short story is, I don't need it anymore. Its been sandblasted and primed. Give me a shout if you need it. I also have the original, working front pump off the Wagner 8N loader.
Phil B.
prbarela at yahoo.com
BKahler
01-30-2005 09:52:53
 Re: wagner loader front mounting bracket in reply to 1941-9NTom, 01-29-2005 18:05:31
I have pictures of my wagner front end loader up on our website. Follow the link below and look for the 45 Ford 2N link at the top left. I'm not sure if the bracket is bolted on the right direction as I've not tried to install it yet. Hopefully that will happen in the next few weeks. If you would like dimensions I'd be more than happy to measure the mount.
By the way the tag on the loader says its a Wagner Ford-2 loader.
Brad
19419NTom
02-01-2005 08:23:02
 Re: To BKahler, wagner loader front mounting brac in reply to BKahler, 01-30-2005 09:52:53
Mr. BKahler,If you would be so kind as to send them to my e-mail address, I would thak you a hundred times for your help in this matter!
BKahler
02-01-2005 16:12:51
 Re: To BKahler, wagner loader front mounting brac in reply to 19419NTom, 02-01-2005 08:23:02
Tom,
Send an email to me at brad.kahler @ 141.com and I'll send you copies as well. I have the bulk of the drawing/sketch done in Autocad, just need to add the dimensions and do a double check on everything. I'm currently checking with a company to see if they can make a few of them for me. I'll let you know.
Brad
Tweeter
01-30-2005 14:00:58
 Re: wagner loader front mounting bracket in reply to BKahler, 01-30-2005 09:52:53
I would like dimension for the Wagner loader mount. Can you email them to me?
BKahler
01-30-2005 16:02:18
 Re: wagner loader front mounting bracket in reply to Tweeter, 01-30-2005 14:00:58
I'll try and get dimensions and a sketch this week. Fortunately its not bolted on tight so it shouldn't be to difficult. Sent your email address to brad .kahler @ 141.com
Brad
Hobo,NC
01-30-2005 07:47:31
third party image
i have some crude draw'ns of this one and a member here has made some fancy draw'ns (Sean Monaghen) and sent'em to me but I could only open one of'em, I will send ya what i got so you kin make it. Told Sean iff'n he was gonna make one he should make a few to sell, I will drop'em a line and see what he has come up with
Sean Monaghen
02-06-2005 14:10:41
 Re: wagner loader front mounting bracket in reply to Hobo,NC, 01-30-2005 07:47:31
drawing of loader bracket
Matt (MN)
01-29-2005 18:50:28
Tom,
You'll probably never find an original mounting bracket, but you never know.
I'm not real familiar with the Wagner loaders, but I'm going to assume there are 3 mounting holes at the front of the loader like the Dearborn family of loaders. All you have to do is cut some strips of steel and drill some holes in the ends of them and then drill some holes in the plate the radiator sits on and bolt the front of the loader to the plate by means of those strips. HTH
Matt
