Trouble under head...
Robert Hesselma
01-30-2005 05:27:53
Hi all,
I believe I already know the answer to my question/problem, but wanted to throw it out in the ring in case I missed something, and to point out the error of my ways.
First, we're talking about an 8-N, had it for 15 years, used mostly for grading and landscape work.
It's been a very good tractor, but has steadily lost power over the years.
This last fall, we had to resort to pulling it to get it started...and so decided to open it up this winter to figure out what was wrong.
Most of the "advice" from well meaning "old guy's" was "it's your rings".
Well...okay, we'll see...I knew the rings were worn cause it burned a little oil, but not much, only a quart a year, and I've owned some real smokers over the years, but they always started pretty easy.
Once the hood and misc. obstructions came off, a compression test showed, starting at #1, 80-35-30-35, not so good!
Removed the head to find VERY burnt exhaust valves on 2, 3, and 4.
Number one was okay.
Cleaned everything up, ground the seats, and installed new valves (all).
With the new valves ground, and lapped in, clearances set, and lots of other work like new wiring, carb rebuild, etc. completed, we decided to put it together with the old head gasket "just to see what would happen".
Compression was now (starting with # 1) 90-100-110-95.
Not perfect, but not bad...after pondering a bit, and knowing we really should pull the engine to rebuild the bottom end, we chose to put it back together (with new head gasket) and see how it ran.
We did, and it fired right up, smooth as silk it ran, for about 5 minutes, at which time it stumbled a bit, and then recovered.
A little later in the day, satisfied that it was in useable condition again, we bolted the radiator on, filled it up, and ran it for a half hour to get it warm so we could retorque the head.
While it was warming up, we noticed oil dripping from the oil filler tube, darn, takes a lot of blow by to make oil drip out (the filter was present)...so, we pulled the plugs for another compression test.
Good news! We had 110-120 across the board...except for #1, it had 0, as in none?
Valves appear to be seating, at least as seen through the spark plug hole, so, if they are okay, the other option is broken rings, a big hole in the piston, or a broken rod?
There is a slight amount of air coming out of #1 on the upstroke, but not enough to move your thumb or get a reading with the gauge.
If the rod was broken, there would be at least a little noise, no?
If the rings were broken (really broken) the blow by from the other cylinders could, in theory, come past the rings on #1 and up through the spark plug hole...no, that doesn't work, as all the plugs are out.
Anyone care to take a guess at this one?
Remember, no noises, nothing out of the ordinary, and it started right up with just a quick pull of the choke...and ran smoother than it has for years.
Really weak rings done in by the new valves...but #1 was the cylinder with good compression before we replaced the valves?
We're gonna tear it down tomorrow.
Rob
canyon indian
01-30-2005 08:43:06
 Re: Trouble under head... in reply to Robert Hesselmann, 01-30-2005 05:27:53
my vote is a valve keeper off leaving your value open ..... please report back your findings and lets hope its a simple quick fix ...
Hobo,NC
01-30-2005 08:17:41
Do a search and you will find 19 hits bout this type in (cylinder leakage test) I only read # 19 and it spains this well. I would not tear into it less i had a good idear were the big leak was.
I do agree valve springs would be a good place to look. If you had done a leakage test first you would have known that #2,3,4 exh was leak'n.
You kin also supply the cylinder with shop air to look fer the leak. It may not show up if you have a weak or broken spring cuzz the air pressure will push the valve closed and show no leakage, DO NOT SUPPLY OVER 100 PSI to the cylinder or you may blow the head gasket. I found this out a few weeks ago on one with a broken valve spring. A run'n compression test showed # 4 to have 0 to 25 lbs compression a run'n and good compression crank'n. Pulled valve cover to find a broke valve spring, added shop air 175 PSI to hold the valves up as I always have done while I replaced the spring and it blew the head gasket this added a nutter $500.00 to the bill. From now on I will regulate shop air. This was on a chevy 2.2L S-10 that I was ready to burn cuzz I could not git a handel on the problem that would come and go. My scope patterns on the ignition were so bad ya could not read'em just new he had ignition problems. I did have to replace the 1,4 coil pack after I replaced the spring and head gasket.
Dell (WA)
01-30-2005 07:48:53
Robert..... ...what an EXCELLENT REPORT and question with INFORMATION, thank you.
I'm with Dan, check yer valves..... ...Dell
Dan
01-30-2005 05:52:32
Well, you didn't mess with the engine or the pistons, so unless you got a lot of crap down in the cylinder when you were working on the head/valves I would say that you should be safe on the piston/engine side of things. Since you did extensive valve work I would suspect a guide/valve binding or a valve keeper popped off and you are loosing compression through a valve opening. It only takes one nut to remove the front valve cover and check, I would start there first.
Good luck and keep us posted,
Dan
Robert Hesselmann
01-30-2005 09:30:22
 Re: Trouble under head... in reply to Dan, 01-30-2005 05:52:32
Dan, and all...
Thank you for the quick responses.
While the head was off, and during the valve seat grinding and other operations, the cylinder bores were covered/protected.
The bores were also cleaned as well as can be without removing the pistons...if anything got in there, it was very small/very little.
Lest anyone misunderstood, my reference to "old guy's" was a way of saying perhaps I should listen to them more closely...as they've taught me well over the years!
Anyway, since tomorrow is WAY too long to wait, I pulled the side cover and found the keepers had slipped, and or been incorrectly installed on #1 exhaust valve, (YAHOO!!!)
My compression readings are now 110-115-105-110, still not perfect, but seems good enough to put the old girl back to work?
Gee, I'm rather glad I decided to post this problem here, and didn't go the usual route of assuming...
Hobo, You're right, a leak down test would have revealed the cause before we ever pulled the head.
We did do a leakdown test AFTER installing the new valves (with the old head gasket)but duh...the keepers weren't installed at the time.
Guess I thought the springs would hold 'em down.
My readings with 90# on the gauge showed only 10-15 pounds holding...figured the rings must be mighty worn out...darn assumptions!
A mechanic I am not, though since my 18 year old son is going to the local college learning to do so, we decided to let him take this project on as a learning experience, he has certainly learned a lot so far!
He installed the keepers while I watched, and kept a screwdriver under the spring, just in case.
Guess dad wasn't doing such a good job of supervising...but all's well now, and he'll be a good mechanic some day.
Soon as my son gets home, I'll give him the good news, and we'll fire it up again, hopefully with much reduced blow by!
He's already itchin to button it back up and start on our next project, a 30 year old V-6 air compressor, 1/2 runs, the other half pumps air.
Thanks again! Rob
Dell (WA)
01-30-2005 20:01:59
 Re: Trouble under head... in reply to Robert Hesselmann, 01-30-2005 09:30:22
Rob..... ...thank you for the feedback. I'm glad it was "nuttin serious". The fact that you included alotta 'pernent' info was a BIG PLUS. Too often, what is intuitively obvious to the reporter IS NOT to this great N-Board of really crackerjack mechanics. BTW thems almost 'braggin' compression readings. Good on you for involving yer son, wheather or not he becomes a line mechanic, the father/son time shared will be great memories in the by-and-by..... ..Dell
Bob
01-30-2005 09:39:19
A leakdown test MIGHT not have caught that one!
My guess is that, with the valves in seats in good condition, the pressure in the cylinder from the leakdown checker would have simply held the valve seated, and it probably wouldn't have leaked!
