Order Ford 8N Parts Online
8n air cleaner
H Kutzler
02-01-2005 11:49:45
Is there supposed to be a gasket where the oil cup fits to the botton of the air cleaner? Mine does not have one.
NT8N
02-01-2005 19:36:03
 Re: 8n air cleaner in reply to H Kutzler, 02-01-2005 11:49:45
Go to your local "O" ring store or parts house and get you a 1/4 inch "O" ring that is to big around for the cup , then cut the "O" ring and super glue it back together to fit the out side of your air cleaner. No more leaks and will out last you. Mine has been on mine for 5 years and still like new and no leaks..... Larry
COLBY N TX
02-01-2005 11:56:05
Yes,
It is a straight cork gasket that you curl into position.
Russ in SoCal
02-01-2005 16:56:17
 P/N 9N 9623-B in reply to COLBY N TX, 02-01-2005 11:56:05
