2N sleeves rings
robert from que
02-04-2005 15:34:44
Got a lovely 2N that is pumping oil when she gets hot and works, my (old)Ford Mechanic says she needs new sleeves and rings and depending on the valves(old type). How much should this job cost . My guy says about 1000.US. Maybe i should do it myself.Need help....
Dell (WA)
02-04-2005 16:31:25
 Re: 2N sleeves rings in reply to robert from quebec, 02-04-2005 15:34:44
Robert..... ....Yesterdays Tractors, the host of this great N-Board, (it is good to support your host) SELLS the full N-Engine overhaul kit (sleeves, pistons, bearings, gaskets) for $320USD. Check'em out, leftsidebar. (order after you find out what size your crankshaft bearings need to be) The N-Engine was designed for horsefarmers, you can operate a computer. Problem with engine overhauls, is "MISSION CREEP". (finding more things that need to be done while ya gottzitt apart) Gittoutt yer I&T FO-4 repair manual ($22USD, cheap) and givitt a preview. Commercially overhauled N-Engines are about $2000USD, ready for installation. What is your time and tractor worth?..... ....respectfully, Dell (who would do his own overhaul if and when needed)
