oil cap blowback
8nNewbie
02-05-2005 15:03:40
While starting the 48' I noticed as it was turning over puffs of white smoke(or thats the best way I can describe it)coming out of the oil fill cap.I never noticed it before,is it normal?
Bruce (VA)
02-05-2005 17:30:58
 Re: oil cap blowback in reply to 8nNewbie, 02-05-2005 15:03:40
Like Ray sez.....it's normal, provided that it's as the engine warms up & it's condensation out of the crankcase. But, if it's blowing smoke out of the oil breather all the time, and most noticably when it's under load, it's from blow-by on the rings. And always use a thermostat.
raytasch
02-05-2005 15:10:11
It is common to see crankcase vapors come out of the oil filler on the N. That is the only crankcase vent, where blowby from combustion vents. "White smoke" would probably be moisture venting and is to be expected during cold weather and a cold engine. Important to run a thermostat so to get the engine warm enough to boil the moisture and vapors off.
ray
Bob
02-05-2005 15:21:12
 Re: oil cap blowback in reply to raytasch, 02-05-2005 15:10:11
Those were made a few years before PCV was required to stop crankcase emissions!
