hydraulic lift question
okie
02-08-2005 16:18:58
I just purchased 8n s/n # *8n153554* and have a problem with the lift. It lifts really well but will not go back down when the lever is pushed down. Overnight it goes all the way down. This makes it tough to use implements. Any ideas?
ZANE
02-08-2005 19:22:59
 Re: hydraulic lift question in reply to okie, 02-08-2005 16:18:58
See the link below for my trouble shooting guide for the 8N tractor.
Zane
HW Pa
02-08-2005 17:08:57
Just an idea..my 2n acted like that so I took off the dipstick cover and moved the long arm that goes from the top cover to the pump. It went down.I loosened the yolk spring tension a turn and that fixed her.LOL
Clay
02-08-2005 16:45:25
Okie,
just put my hydraulic pump back together with new gaskets and sealant. was having trouble lifing round bales, the oil was contaminated with water. put 90 weight back in, it won't lift but goes down alot slower. if its cold and the oil is thick it may be passing through the exhaust valve slow.
Clay
hooker
02-08-2005 16:57:38
 Re: hydraulic lift question in reply to Clay, 02-08-2005 16:45:25
what size are the round bales your lifting???
Clay
02-09-2005 13:11:38
 Re: hydraulic lift question in reply to hooker, 02-08-2005 16:57:38
I am lifting close to 1000 lb bales, lifted before this a recent problem. Oil was milky, did not see any cracks.
