Everyone has me puzzled
Rex from Indian
02-11-2005 19:31:16
I have a 1950 8N.(6v) I believe it has a bad coil(tractor runs for 20 min. then runs rough with very little power). I would like to convert to 12v. I am not a electrical gooroo, but I do have a degree in engineering. I would like to all this converting at the same time.(new coil,altenate etc.)
1.) Can a novice do this without much problem?
2.) Should I go to a electronic ignition or stay the course with points and condensor?
I know there will be many differing opinions.
Let the fighting begin!!! I would appreciate any suggestions.
Tom in MS
02-12-2005 05:46:24
 Re: Everyone has me puzzled in reply to Rex from Indiana, 02-11-2005 19:31:16
Best, simplest, cheapest way.. Easy..check it out.
http://members.cox.net/sean.monaghen/larry12volt.pdf
bj/8n/mt
02-12-2005 05:19:37
Whether you convert or not get it working right before you start. Trouble that is hard to find now will be twice as hard to diagnose if you have to wonder if it is something to do with the conversion.
Your mileage may vary
jwm
02-11-2005 20:08:26
To answer your question,yes, this can be done by a novice.Since you already have a engineering degree that indicates you have some smarts. There are several fine articles about converting to 12 Volts on this very site. Look over to the left under "Articles". You should find all the information you need. As to weather or not you should go to Electronic Ignition or not, this is for you to decide. You may want to investigate an Electronically Assisted Ignition. Thats what I did and it works great and is very cheap, comparatively. Do some reading and then form your opinion. Good luck and have fun. James
Rex from Indiana
02-12-2005 17:52:42
 Re: Everyone has me puzzled in reply to jwm, 02-11-2005 20:08:26
Thanks for everyones comments. I'll keep reading this forum for various articles. Can't wait to get started. If I screw it up, you'll be hearing from me. Thanks, Rex
Dell (WA)
02-11-2005 19:50:46
Rex..... ....there are 4-common runtime issues with N-Tractors.
1) runs good for about 1 minute and quits. Bad ignition condenser; not your stated problem
2) runs good for about 5 minutes and quits; clogged fuel filters; not your stated problem
3) runs for about 1 hr and quits; restarts after overnite cooling; bad ignition coil; NOT yer stated problem 4) runs for about 15 minutes and quits; restarts after cooling-off an hour;
Sound like yer stated problem? BAD IGNITION SWITCH GUTTZ. You doubt? Next time, use a jumper wire with alligator clippie to by-pass the ignition switch terminals at the "T" termial block underneath yer ammeter behind the dash..... .....respectfully, Dell, yer self-appointed sparkie-meister
steveormary
02-12-2005 11:08:46
 Re: Everyone has me puzzled in reply to Dell (WA), 02-11-2005 19:50:46
Rex;
Go with 12 volt and electronic ignition.
steveormary
