Order Ford 8N Parts Online
8N sudden loss of Oil Pressure
RogerR
02-13-2005 16:51:55
started tractor notice there was no oil preasure
registering on gauge. removed oil line from gauge
no oil pumping. I recently changed oil and filter
the tractor had been sitting for sometime. Manual doesn"t show oil routing. Looking for ideas before tearing down? Maybe there"s something I am overlooking?
RogerR
02-14-2005 15:49:50
 Re: 8N sudden loss of Oil Pressure in reply to RogerR , 02-13-2005 16:51:55
thanks for the help. Tractor now has oil pressure.
John-Michigan
02-13-2005 17:21:10
You may have answered your own question.
When you changed oil and filter did you fill the filter canister with oil? It will take a few seconds for the pump to fill the system.
Or, you may have accidently jammed the drain plug screen against the oil pick-up tube and cracked the pipe at the pump.
Dell (WA)
02-13-2005 17:20:04
Roger..... ..ya done went an lost yer oilpump prime. Worn tractors that set for a long time do that. Changing oil/filter is good but really has nuttin to do with loosing prime.
Look for a BIG bolt head behind yer waterpump. It is the oilpressure relief valve. It is springloaded and yes it is supposed to have a flatspot on its side. Pour/squirt some HEAVY OIL into your oilpressure relief valve hole and it will prime yer pump.
Do not use regular engine oil as it will leak out before you gitta chance to run around and start yer engine. A little heavy oil ain't gonna hurt nuttin. I use heavy 140wt outboard motorboat lower unit oil in a pointed plastic squeeze'm tube. Simple, eh?..... ...Dell
