Sure Seal
RedTail
02-15-2005 19:24:52
I am taking apart the rear axle on my 9N, I was going to put on a new sure seal, but it looks like there is an old one on there. How do you get them buggers off? I can seem to grip on to anything to pull it off.
Drmeatman
02-16-2005 11:22:12
 Re: Sure Seal in reply to RedTail, 02-15-2005 19:24:52
Red,,,ooops, I had a senior moment. I gave wrong take on this. I just finished both sides of my 8n, seals, bearings etc. and that had "locked in" plus the flu didn't help. SORRY !!
Drmeatman
02-16-2005 04:16:27
Red, you have to remove the hub and the sure seal is bolted to the break assembly and bearing cup assembly.Not too big a deal except removing the wheel hub.Some advise backing off the (big as your fist)axle nut 3 turns and doing a figure 8 a couple of times to "loosen" the hub.I did. You can do IT.Gets easy after the hub comes off.
SteveB(wi)
02-16-2005 04:57:07
 Not applicable to 9N in reply to Drmeatman, 02-16-2005 04:16:27
9N does not have seperate hub. Follow Toms advice.
Tom in MS
02-16-2005 04:12:21
Beat and bang...I had to drive a thin punch in the top lip down next to the axle..Getting the old one out is the toughest part of the job..
Russ in SoCal
02-16-2005 07:55:18
 Re: Sure Seal in reply to Tom in MS, 02-16-2005 04:12:21
Wonder if a dent puller would help?
Russ
RedTail
02-16-2005 06:05:14
Thanks that was my next step but didnt want to mess it up till i was sure that was the way to go.
