Order Ford 8N Parts Online
8N engine overheats
Olas Lunt
02-16-2005 11:49:10
My 8N runs great except when I put a load on the engine (such as when I"m disking) Radiator boils over. Since I have no temp gauge on the tractor I don"t know if I"m operating it at too high a temperature. Shouldn"t the radiator cap seal and pressurize the system? If so , how can I get a better seal?
clearfield
02-17-2005 05:42:19
 Re: 8N engine overheats in reply to Olas Lunt, 02-16-2005 11:49:10
Olas
I had the same problem last year I took the old gilr up to my backyard and took the garden hose and sprayed the fins in the radiator
you should of seen the crap that came out it took a while before it flushed clean that took care of my problem clearfield
Bruce (VA)
02-16-2005 12:37:34
Chances are you have over-filled the radiator, like Danny sez. Or, you have a slipping fan belt or debris in the front of the radiator. Less likely, but possible, is a stuck thermostat. If it's the thermostat, make sure you replace it; you will get abnormal engine wear from running w/o one as the cylinders will be operating at different temps. Finally, at the bottom of the probability list, is a clogged radiator or water jacket in the block. These old radiators do not take well to cleaning, so worst case is a new radiator. Cap is 4 lb.
Danny in CO
02-16-2005 11:52:47
Don't fill your radiator to the top or it will boil over. I run mine about 6-8" below the cap level with no problems.
Danny
