Order Ford 8N Parts Online
8N vs Round Bales
Dan Bowles
02-16-2005 18:22:29
I have someone asking about using an 8N to move 800 pound round bales. I assume this is with one of the 3 point spears. I"ve never done it myself but thought I"d ask the experts!
Hydraulics are good and strong with everything else I do...
Thanks
NO . . . Dell (WA)
02-16-2005 22:38:35
 Re: 8N vs Round Bales in reply to Dan Bowles, 02-16-2005 18:22:29
Dan..... ..while the N's hydraulics (in good shape) can lift about 1200# (iff'n ya chain the front-axle to the ground) before the hydraulic pressure relief valve blows-off, the short wheelbase causes the frontwheels to start flappin' innna the breeze at about 750# on the rear lift. N's just are NOT roundbale spearchunkers.
Howsomevers, they make a single axle "doodle-bug" stinger trailer that will pick-up 2500# roundbales that your N-Tractor can eazily tow..... ...Dell
Russ in SoCal
02-17-2005 07:56:42
 Dale Bolley in reply to NO . . . Dell (WA), 02-16-2005 22:38:35
third party image
billOH
02-16-2005 18:46:50
You might be able to move one or two in an emergency, but the N is generally speaking too small to muscle round bales.
KEN B...OK
02-16-2005 18:44:55
AFTER I HAD MY HYDRO. BROUGHT UP TO SPEED IT WILL IF I CAN KEEP THE FRONT WEELS ON THE GROUND.
BY THE WAY IF YOU DONT MIND WHERE DO YOU LIVE?
Dan Bowles
02-17-2005 03:34:24
 Re: 8N vs Round Bales in reply to KEN B...OK, 02-16-2005 18:44:55
Thanks to all. I guess it pretty much means NO.
I'm in SE MI by the way.
Dan
