Premie..... ..while electronic ignition "fixxes" alotta points problems, FIRST ya gotta fixx yer current points problem. Iff'n yer always having to re-gap yer sidemount points (0.025"), then yer points screw is slippin' gitta NEW SCREW. #8-32x3/16" ($50c, cheap) its a special SHORT screw but quite common in ignition system. Screw threads wearout, you can't see it without special measuring equiptment. Iff'n yer always haffin to clean yer points because of invisable crud, then yer distributor bushings are worn and needs rebuilding. Condensers don't suddenly go bad, but can go bad over years of use. Look at yer points, are they pitted, bad condenser. Condensers are known to be bad directly outta the box. Remember the 6 volt mantra: "keep'em clean, bright, and tight" and don't be fer usin' enny of them thar wimpy ferrin battery cables. Gittcha some 'arrychested 'mericum made one-ought (1/0) thick as yer thumb battery cables for improved engine starting..... ...Dell, yer self-appointed sparkie-meister
