What else- ain't startin'
8ngreenhorn
02-19-2005 14:14:29
N was starting perfectly until I changed the oil. Now turns over, but won't fire. I have spark, its white/blue and bright. I have gas that's getting in the carb (which I successfully rebuilt about three months ago). It turns over but doesn't sound as if it's firing. Sometimes It gets close but no further. I may have put in about a quart too much oil when I changed (got my vehicles mixed up). I just read a post where a guy put oil in the cylinders and it fired up ... ?
greywynd
02-20-2005 00:14:53
 Re: What else- ain't startin' in reply to 8ngreenhorn, 02-19-2005 14:14:29
Any chance you put that extra quart in the air breather and are now choking it? I don't think an extra quart would fit, but, it is easy to overfill them.
Mark
ericlb
02-19-2005 16:52:36
if you have gas to the cylinders, and fire to the top of the plugs, it may be the plugs themselves, pull one and ground the plug body , then turn the engine over and watch to see if the plug fires, let us know what you find, ericlb
HOOKER
02-19-2005 16:10:58
pull the air tube off the carb, give it a wiff of starting fluid if it fires up it's in your carb, if not it's in yer fire or could be a combo of both
keep us posted we'll get it going fer ya
Ken N Tx
02-19-2005 15:15:50
Only changing the oil should have nothing to do with it not starting..
You may have read were someone put Mystry Oil in the cylinders to free them up..and then it started.
HOOKER
02-19-2005 16:06:56
 Re: What else- ain't startin' in reply to Ken N Tx, 02-19-2005 15:15:50
i think he was reading on matt bennett's post where he shot oil in the cylinders cuz of low compression??
