White/blue spark
8ngreenhorn
02-20-2005 05:05:25
My spark is white/blue and pretty strong. Put starting fluid through the carb air port. Nothing. I know oil has absolutley nothing to do with it, but my N started until I changed the oil.
waddya think?
Dell (WA)
02-20-2005 11:22:03
 Re: White/blue spark in reply to 8ngreenhorn, 02-20-2005 05:05:25
greenhorn..... ....just lookin' at yer white/blue sparkie don't mean 'nuttin'!!!
DOES IT JUMP 3/16" GAP???
Make a "calibrated" sparkie tester outta enny ol'sparkplug by bending the side electrode out for a full 3/16" gap. Now ground the shell to handy engine bracket and plug enny sparkie wire to top of tester. NOW does it jump a full 3/16" gap with blue-snott authority?..... ....respectfully, Dell yer self-appointed sparkie-meister
James41-9n
02-20-2005 08:20:15
did you change the oil in the air filter? If you overfilled that, could the carb not be getting air, or could oil have been sucked down into the carb, and is not gumming everything up?
HOOKER
02-20-2005 05:54:03
hows the compression if the compression is low then that means your vaccuum will probably be low too. keep us posted
billOH
02-20-2005 05:22:53
It sounds to me like you have a vacuum leak. Take off your carb and check the manifold gasket. Replace if necessary. Also make sure the fuel line entering the carb is snug.
