Order Ford 9N Parts Online
Carb question 9n
ricks41-9n
02-22-2005 12:44:42
I need to replace the carb on my 1941 9n and would like your opinion on which brand to use. Marvel/Schrebler or Zenith. Thanks Rick.
souNdguy
02-23-2005 07:58:28
 Re: Carb question 9n in reply to ricks41-9n , 02-22-2005 12:44:42
I know a few years back, the MS copy carbs from TSC weren't too great.. however.. I bought one the other day to retrofit a failed and NLA zenith on an early contental/red seal power unit.. and the carb worked great. i adjusted it pretty much using Dell's conventional idle and mainjet basic instructions.. and it worked perfectly.. with no other adjustments. Their quality is slowly improving.
Soundguy
patternmaker
05-23-2005 06:48:52
 Re: Carb question 9n in reply to souNdguy, 02-23-2005 07:58:28
I have a Red Seal engine in a Jackobsen Homelite tractor. What is the carb model you put on yours?
Tom in MS
02-22-2005 17:07:26
Installed new Zenith on 2N a few minutes ago. I have two MS carbs in top shape and another new MS copy. Zenith runs and idles better than any of the others..Zenith a little pricey but definitely better idle circuit than the MS in most cases..One of the MS I have will idle down to nothing..
Tymoc
02-22-2005 16:30:22
Just gotta know. Why do you think you need to replace the carb. Missing?, Busted? I bet some one on this board has a good original carb. laying around if you ask. If you have one now you CAN rebuild it and it will be better then most of the new ones.
Dave H (NY)
02-22-2005 16:15:07
If your old carb can't be rebuilt for some reason do yourself a favor and fine a good used carb, so many of the new aftermarket carbs are giving guys trouble it's not worth the aggrivation of using them. I had the displeasure of buying a new carb and had nothing but trouble with it,after suffering through a score of other tests and troubleshooting I purchased a used carb bolted it up to the 2n and it never ran better.
D Masury
02-22-2005 13:03:11
I replaced the carb on my 41 9N almost a year ago..it had an oversized zenith...I have a lot of experience with zenith carbs on another engine.. the one I took off was too large an thus could not be leaned down enough to stop from running too rich... I replaced it with a Marvel/Schrebler look alike and have no problems with it other than some stray dirt from the old fuel tank... cleaned the tank, put on a new fuel shut off, cleaned the carb and thats it....
