Sluggish at Full Trottle
Rod
03-22-2001 17:44:16
I rebuilt the 8N Carb twice, checked the ignition, both by the book, but it still boggs down under a load. I can manually pull the carb linkage and it runs better but the Govenor pulls it back. It idles fine and purrs up to 1/2 trottle, then boggs down, it doesn't die, it just does not want to go full trottle even without a load. Help!!!
bg
03-22-2001 20:57:09
 Re: Sluggish at Full Trottle in reply to Rod, 03-22-2001 17:44:16
Take the governor apart and check for wear. Adjust it when you get it back together. Also check the centrifugal advance mechanism inside the distributor body.
Rod
03-23-2001 15:58:07
 Re: Re: Sluggish at Full Trottle in reply to bg, 03-22-2001 20:57:09
OH GOD!
I was afraid someone would tell me to open up the Governor, I had just graduated from Carburetor School, I don't think I'm ready yet!
bg
03-23-2001 23:07:13
 Re: Re: Re: Sluggish at Full Trottle in reply to Rod, 03-23-2001 15:58:07
Go ahead and open it up. Two bolts to remove it, and few moving parts inside. It ain't that difficult. I&T FO-4 has repair procedure.
