idle jet
ndjdn
02-23-2005 11:38:39
does anyone know what the threads are on the idle jet on a tsx241c caburetor????
ndjdn
02-23-2005 13:14:13
 Re: idle jet in reply to ndjdn, 02-23-2005 11:38:39
OK, now not only that, but now where can i git the jet?? is there some of those rebuild kits that would actually include em??
Dell (WA)
02-23-2005 15:14:57
 Re: idle jet in reply to ndjdn, 02-23-2005 13:14:13
ndjdn..... ....8N M/S TSX-241C, idle jet, p/n 8N-9596, $2 (cheap). Available from many on-line N-Ford parts specialists, including the sponsors of this great N-Board. Do a search..... ...respectfully, Dell
Dell (WA)
02-23-2005 11:56:45
ndjdn..... .....#8-32 thread for M/S idle jet. ALWAYS USE "gun-smithing" hollow ground screwdrivers and you won't muck-up yer brass carb jets and haffta drill'em out..... ....Dell
Rusty8N
02-23-2005 12:35:10
 Re: idle jet in reply to Dell (WA), 02-23-2005 11:56:45
Dell, please elaborate on these hollow-ground gun smithing screw drivers you always mention...where can one get them???
Dan
02-23-2005 19:09:13
 Re: idle jet in reply to Rusty8N, 02-23-2005 12:35:10
Get you some cheap $.99 small screwdrivers from Walmart and grind the tip and sides down until they fit perfectly into the jet slot. You can use the idle jet as a test as it is real easy to see and get to. The pic rurlndum posted below is an EXCELLENT pictorial of what you are trying to acjieve.
Dan
Inspired
02-24-2005 13:50:32
 Re: idle jet in reply to Dan, 02-23-2005 19:09:13
I agree Dan,
Who wants to pay $10 for one of those fancy gunslinger screwdrivers.
Inspired
Dell (WA)
02-23-2005 12:54:30
Rusty..... ...I could say "what part of HOLLOW-GROUND" don't you understand?
Most common screwdriver blades are tapper or wedge shaped. LOOK and pay attention.
I got one of my carb screwdrivers from "Snapp-On"; 'nuther from local mega-hardware store; 'nuther from would you believe? "Tacoma Screw". Look and pay attention, they are precision and expensive but you don't need a whole set.
As I said, hollow-ground gun-smithing screws won't hogg-out yer brass jets slots and make ya haff all sortta removal problems of drill and tappin corroded-inn jets..... .....Dell
rurlndum
02-23-2005 17:03:54
 hollow ground screwdriver blade in reply to Dell (WA), 02-23-2005 12:54:30
third party image
Maybe this image can help the concept of a hollow ground screwdriver blade. Neat tools!
