Order Ford 8N Parts Online
8n rebuild tools
Prince8n
02-23-2005 13:15:38
I have a 1952 ford 8n that will bneed to have its engine rebuilt.
I planon doing this myself.
I will be ordering a kit after I tear it down.
What tools will I need to rent or buy ?
Prince8n
Drmeatman
02-23-2005 20:02:53
 Re: 8n rebuild tools in reply to Prince8n, 02-23-2005 13:15:38
Prince8n,most average tool chest will get you through with the vast knowledge of this board. You can do it.I had a "friend" to help me with my 1st. one.Done 2 since. Not professional mind you but they perform nicely at tractor meets so I'm pleased.Bring your questions (and frustrations) here and these fellas will help you.I've even heard ones that have used the vidios and seem to like those.
SteveB(wi)
02-23-2005 16:07:39
Here is a link to a good thread.
hvw
02-23-2005 14:27:43
The biggest tool you need is this board, and it's free. Ask a lot of questions as you go.
Jeb2N
02-23-2005 14:22:50
I would recommend that you go and buy a set of "Stud Extractors" from Harbor Freight. They look like a set of sockets with 3 long, skinny, rods inside. As you turn the "socket", the rods actually clamp down on the studs down the entire length of the socket so the stud is much less likely to break off than the old double-nut method. And, at harbor freight, a set (4 sockets) is only like $15. Well worth it for what they do in my opinion!
Jeb
valhallareject
02-23-2005 14:18:44
and tappet wrenches. My dad used to tan my hide when he caught me using the special tappet wrenches on plain old ordinary nuts and bolts. Sumptin about being shaped just right and not too thick or too deep....I dunno....but you know how it is....tell a kid not to use sumptin....and oh well...I finally figured it out...and it only took me 25 years!
HOOKER
02-23-2005 14:17:56
a small atv/motorcycle jack works great when splitting the tractor (personally i went to a saw mill and bought 2-16"x16"x24" blocks but i also have a forklift to do all my lifting)you wont need a big set of 1/2" drive sockets but you will need a 1 1/16" to get the big bolt off the crank (front) the rest of the hand tools will be a normal set of tools SAE
Dan
02-23-2005 17:44:28
 Re: 8n rebuild tools in reply to HOOKER, 02-23-2005 14:17:56
My stock crown head (for a hand crank) crank bolt for my NAA was 1 5/16" - I had to go buy a special socket just for that sucker!
Dan
robert1
02-23-2005 13:52:39
Hi Prince! A good torque wrench is a valuable investment. Valve spring compressor and piston ring expander tools could probably get from a loaner program at an auto parts store. I think Auto Zone and others do it. Good luck.
