Order Ford 9N Parts Online
Resistor Check 9N
RussellTX
03-22-2001 20:05:19
I have a 12-volt conversion with 6-volt coil with in-line resistor. What should resistance read across resistor with key off? Should I see a difference in voltage on resistor terminals with key on? And what voltage should I see at the coil with key on but engine not running? I had a resistor burn out the other day which I replaced. Started the tractor and found the alternator was putting out 15 volts with 10 volts measured on the far side of the resistor. Swapped out alternator and had a 14-volt reading off of alternator and 9.5 on far side of resistor. Is this latest reading normal? Thanks in advance for you guys help.
ZANE
03-23-2001 18:06:54
 Re: Resistor Check 9N in reply to RussellTX, 03-22-2001 20:05:19
Reading all this stuff about the coil voltage on the 6V front mounted distributor made me think of what I saw this past week.
I am re-ringing an 8N for a neighbor and he has it converted to 12 volts side mounted distributor. the odd thing was that he had installed a ballast resistor for the coil but instead of putting it in the circuit coming from the ignition switch to the coil he had the risistor in the circuit between the points and the coil. It ran is all I can say! I don't know if this could possibly reduce the voltage to the primary windings of the coil or not but all I know is that it would run!!!!
I am putting it back in the proper circuit before I try to start the enging when I get it back together.
Another unusual think I saw today was the ignition wiring circuitry on a 31 Model A Ford car. I would have thought that being so much like an N they ignition wiring circuit would be much the same @ Hot wire from the ignition switch to the risistor to the coil. Points to the coil circuit. Not so. The ignition switch is in the circuit between the points and the negative post of the ignition coil and the positive post of the ignition coil is hot all the time. This the way the wiring schematic shows it and the way the wiring harness is made and it runs too!!!!
What blew my mind was the fact that the primary winding in the coil is attached at one end to the battery at all times and is hot. When the switch is closed and the points make contact is the only time their is any current draw.
Phil (AZ)
03-23-2001 19:28:25
 Re: Re: Resistor Check 9N in reply to ZANE, 03-23-2001 18:06:54
Zane, Interesting, but you can break current flow anywhere and it has the same effect. I am still waiting for "Al English" to ident which side of the coil is commom to both Primary & secondary. This has much more interesting issues.
JMHO
ZANE
03-24-2001 16:02:15
 Re: Re: Re: Resistor Check 9N in reply to Phil (AZ), 03-23-2001 19:28:25
I have read about the primary and secondary being connected somehow but I still haven't gotten that straight in my head yet!
I think I will get a coil tomorrow out at my shop and look at it with an OHM meter to determin just how this can be or is.
Phil (AZ)
03-24-2001 16:59:05
 Re: Re: Re: Re: Resistor Check 9N in reply to ZANE, 03-24-2001 16:02:15
Zane, I won't be back to the farm until april 15th to do any checking, but you should have High Resistance between the Output(Hi voltage Term) and both terms on primary. The best way to determine which is the "one" common, is to use an external Bat attached to the Ouput (hi-voltage)term (bat +ve) and One of the Primary (Bat -ve) term. Then you use your meter in "current" mode to measure the Current in the other term of the Primary, +ve probe on primary connection and -ve probe to -ve Bat. Record the current reading then switch the primary connections and record reading. The One that has the highest current is the one that is common to the secondary
Phil
Dell (WA)
03-22-2001 21:00:28
Russell..... ...Have you checked the "achives" at the top of this great N-Board? Many Q&A about this same situation.
And the correct voltage reading depends upon wheather you have a frontmount or a sidemount ignition system and you didn't say. And unfortunately for you, I flunked mind reading, just ask my ex-wife.
But for your direct enlightenment, 9.5 or 10 volts on any 6 volt coil is much, much, much too high. Wheather you have a frontmount ignition or a sidemount system. It will burn out your ignition coil.
Trust me on this, most readily available ohmmeters really are not too accurate in the low ohm ranges, specially when you try to read less than 1 ohm. Howsomever....even the cheepest voltmeter is accurate enuff. Its just the way there made. And besides that, to read ohms you must have one end of the resistor waving in the air so that you don't have any ground loops, and/or hidden parrallel resistances.
Oh, and by the way, if you have a frontmount coil, you will need 2 resistors connected in series, like flashlight batterys..... .Dell
RussellTX
03-22-2001 21:43:00
 Re: Re: Resistor Check 9N in reply to Dell (WA), 03-22-2001 21:00:28
Now I'm really confused! I do have a front mount coil - however, I have only one resistor which came with my conversion kit from my local tractor dealer who deals alot with older tractors. I know this shop does many conversions and they only use one resistor. I was getting 10 volts on the farside of the resistor and about 3 volts on the coil with key on - engine off. Enlighten me - how can that be? And as far as the resitance on the resistor - it shows an open circuit. That make sense?
Dell (WA)
03-23-2001 12:53:23
 Re: Re: Re: Resistor Check 9N in reply to RussellTX, 03-22-2001 21:43:00
Russell..... .ah yes, the 6 volt frontmount ignition coil.
The 6 volt frontmount ignition coil requires about 3.5 at the coil terminal with the points closed (2.5 min, 4.0 max) and battery voltage with the points open. Anyother voltages is going to give you sparkie problems. This is accomplished with the infamous "ballast resistor" in the original 6 volt scheme.
Therefore, based upon what you have just reported as the voltage at your 6 volt frontmount ignition coil as being about 3 volts, you're right in the ol' ballpark.
As for your 10 volts on the far side of your conversion resistor, that is what I would expect at the junction between the OEM 6 volt "ballast resistor" and your 12 to 6 volt converting resistor (that came with your conversion kit) that you must have installed between the ballast resistor and the 6 volt frontmount ignition coil. And you probably don't even know it.
HOWSOMEVER...if you are absolutely certain that you don't have the original ballast resistor mounted on the backside of the dash panel, and will swear in Henry's name to all that sacred, that it is not there, then I'd be concerned that your ignition switch internal contacts are gunkin' up and providing a hidden resistance that is going to bite you. Old Ignition switches are notorious for doing that.
Eazy check, make a short jumper wire with alligator clipies on both ends and jump across the ingnition switch leads, if your ignition voltages increase, then you know what to do, replace the ignition switch.
Oh yes, the converting resistor, I'll really bet it reads about "zero" ohms, not "open" because if'n indeed it was open, you wouldn't read any voltages at the ignition coil at all. And the reason it reads about zero ohms is as I said, most common ohm meters don't read very accurately at less than 1 ohm, which is what the typical 12 to 6 volt converter resistor usually is..... ..Dell
RussellTX
03-23-2001 16:47:19
 Re: Re: Re: Re: Resistor Check 9N in reply to Dell (WA), 03-23-2001 12:53:23
Dell, Phil, and Dave. I do appreciate all of you guys input. But you know, just about the time I think I'm just .075 brain neurons short of being a rocket scientist when it comes to these tractors - you guys shoot me down. I will say you guys are right in all you indicated (and yes, Dell, you were right - I was registering 0 ohms and not an "open circuit"). I did get her running and back down to the house and she seems to be running fine. There is something to be said for working out in the field on your tractor at night, however, - and that is you can see wires arcing when you've got a short. But since the regulator was hung up earlier and burned up my resistor, I was concerned it may have done so again. But just FYI, here is what I've got. I do have a single resistor that came with the conversion kit that is mounted where the old one was. Here's my readings:
Key On - Engine Off
Battery - 12 volts
Alternator - 12 volts
Hot side of resistor - 11.5 volts
Coil side of resistor - 2.5 volts
Coil - 2.5 volts
Key On - Engine Running
Battery - 14 volts
Alternator - 14.5 volts
Hot side of resistor - 13.5 volts
Coil side of resistor - 8 volts
Coil (measured very carefully) - 8 volts
So thanks again - I think I'll drink a cold one and review the formula for Ohm's law (not!). Till next time...
Phil (az)
03-23-2001 19:18:11
 Re: Re: Re: Re: Re: Resistor Check 9N in reply to RussellTX, 03-23-2001 16:47:19
RusseLL,
Your Post: "Coil side of resistor - 8 volts
Coil (measured very carefully) - 8 volts"
You can measure as carefully as you want but it still has "NO" meaning.
Jmho
Dell (WA)
03-24-2001 00:22:48
 Re: Re: Re: Re: Re: Re: Resistor Check 9N in reply to Phil (az), 03-23-2001 19:18:11
Phil..... .You're right, 8 volts at the coil on a running engine has "NO meaning", for many technical reasons. Lets not confuse Russell anymore than he already is (grin).
I'm more concerned that he is reporting a voltage drop across his ignition switch. I'd recommend that he replace it before he comes asking why his tractor will only run for about 15 minutes and cuts out and won't start again without waiting for an hour or so..... ..Dell
RussellTx
03-24-2001 06:29:30
 Re: Re: Re: Re: Re: Re: Re: Resistor Check 9N in reply to Dell (WA), 03-24-2001 00:22:48
And I think I'll check out that ignition switch today.
Phil (AZ)
03-23-2001 07:32:15
Russell,
The ballast Resistor is a Current Limiter, the resistance increases as current increases and at a (the) defined limit(brick wall)the ballast resistor will oppose increased current. This brick wall has a limit and when exceeded the resistor will burnout and/or current will increase without limit.
The Voltage Vs Current characteristics of a particular Ballast Resistor need to be plotted and the corresponding resistance values calculated. This was done for the Standard N ballast, about 2 years ago, and the results were posted on this Board. The most important point in the graph is the 2.4 Amps brick wall (@ 1.75 ohms to ~ 2.4 ohms).
It can be determined that you require 2 Standard ballast resistors, in series, for a 12 Volt Front Mount. The voltage at the Coil will be ~ 2.4 Volts, with point closed.
Measuring voltages, with a meter, with the tractor running is meaningless in the ignition circuit. You need a Scope as the important characteristics are in the lowest values(minus battery) of the waveform. JMHO
RussellTX
03-24-2001 06:39:04
 Re: Re: Re: Re: Resistor Check 9N in reply to Phil (AZ), 03-23-2001 07:32:15
Phil - I went back and read your post. And I think I understand what you are saying. With one resistor I'm getting the approx 2.5 volts a the coil. The resistor that is in there now is much larger than the one originally on the tractor. Is it assumable they have designed the one resistor to do the work of two?
DavidO
03-23-2001 04:59:49
A couple of thoughts. All 12 V conversions are not the same. My 12V conversion included changing to a 12V coil (front mount) and using the original resistor in which case 9.5 to 10 V at the coil is fine with the points closed, battery voltage with the points open. There are a lot of posts regarding 12V conversions in the archives. First take a good look at the details of your wiring and components, then check the archives for related information. Let us know what you find. Good Luck.
