Learned two things today...
Ramrod
02-26-2005 09:46:22
1. The Old Warrior's reserve tank valve actually works, a good thing.
2. The front spindles look alike, but the left spindle will work much better if you install it on the left side. Likewise for the right one... DUH
Felt smart when I figured out the first thing, but the second thing cancelled it out!
Ramrod
Russ in SoCal
02-26-2005 10:58:11
 Re: Learned two things today... in reply to Ramrod, 02-26-2005 09:46:22
Ramrod,
Once upon a time, (or, to put it in Redneck: "Y"all ain"t gonna believe this s___, but...") John Smith pointed out how to tell left from right on them spindles. Look down on it from the top with the wheel axle at three o"clock. If the steering arm is at ten o"clock, it"s a RH. If the arm is at eight, it"s a LH.
Now, if somebody would just come up with a way to remember this.
Russ
premie-farmer
02-26-2005 10:25:47
Me too!
1. take Dells advice on clean bright and tight.
2. bigger battery cabels are best.
Reasons my old girl wouldn"t start found previous owner used automobile batt cables. Found terminal block covered with 50 years of farm dirt shorts out the wiring and even a new 1 year old key switch can be defective (hast to be turned just short of all the way up to make continuity). My old girl turned over and ran well after a little encourgement (hasn"t ran since September) once I took the terminal block off and cleaned the corrosion off and the dirt. Plus the big hocker battery cable helped I"m sure. Thanks for the advice Dell.
