If you are fixing the brakes and axle seals.. you should be good to go as long your tranny isn't prone to popping out of gear. Never press the clutch in and shift out of gear on a steep grade.. You'll have a hard time getting back in gear and will only have brakes to slow you down, instead of the engine and tranny to help. Your 8n will pull plenty of trailer, hay and people. I pulled a 16' car hauler, 12 bales of square hay, and about 10 adults and a couple kids. i built a 2x4 frame with rails around the trailer for 'safety'. I used a surplus 12v car battery and a spar blinker assembly and some jumper wire to wire the trailer lights up to flash, and I added a SMV plaque to it. I also used a small 150w inverter to power a couple strings of xmas lights strung around the trailer. My tractors (2) 35w 6v lamps ( still 6v.. that's why the 12v car battery on the trailer. ) provided plenty of driving light. We did this at christmass and did some carolling. Those little 12v neon 8w bulbs work good to be able to read from song books. Had I been worried about it, it wouldn't have been hard to righ up an old headlamp switch from the battery to the electroninc brakes on the trailer to use as an 'emergency' brake in case the tractor brakes weren't sufficient. I'd load test the tractor on a hill with dead weight.. and if it passes.. don't worry about it. If the tranny pops outta gear.. keep a bungy strap on it from the seat spring.. lotsa farmers did that. If you don't have a swinging drawbar.. make or buy a set of stays to keep your 3pt drawbar DOWN while towing. Above all else...Be safe.. but have fun and make some great memories. Soundguy
