Make that THREE things learned!
Ramrod
02-26-2005 13:24:11
3. Zane's $40 kit for the NAA control valve don't look like much (neither do I), but (like me) it's worth it's weight in gold.
Plain language, clear pics, easy to understand instructions. I have two shop manuals, both have procedures for the hyd control valve adjustment that I studied, didn't make sense to me. Zane's manual told ne where the trouble was and how to fix it on the first pass. I now have position control and draft control working and tested. Zane even tells you how to test it before you put it back on the tractor, the other two didn't.
Thanks Zane!
Ramrod
Dan
02-27-2005 05:56:34
 Re: Make that THREE things learned! in reply to Ramrod, 02-26-2005 13:24:11
Yep - the manuals were like reading Greek. I did not have the jig or the spacers so I had to wing it with a ruler and a "guesstimate" in the hydraulic arm placement. I have been worried since I put it back on that it will not work right. I did not find out about Zane's stuff until after I put it back together, and did not want to take it back apart until I knew if it would work or not. I would have LOVED to know how to test it BEFORE I put it back on! If the instructions are as good as you say, I'll go ahead and order it just for knowledge the next time I rebuild one.
Thanks for the testimonial, I should have known Zane would have had something.
Dan
