Dearborn 10-156
Poppey
02-27-2005 06:43:32
I have a Dearborn 10-156 or 10-216, 2-14" bottom plow. My question is what size are the rolling coulters suppose to be?
bob9N wny
02-27-2005 10:53:27
 Re: Dearborn 10-156 in reply to Poppey, 02-27-2005 06:43:32
Poppy
I went out and measured my coulter brackets and they could take 16" dia. Maybe there were different mounts?
There should be an ID tag on the right side tower of the plow with the mod. nr. on it.
bob
Poppey
02-27-2005 14:04:32
 Re: Dearborn 10-156 in reply to bob9N wny, 02-27-2005 10:53:27
Thanks for your help! I remeasured mine and your right it will take a 16". Do you know the center hole size, and were do you get replacements? The tag is gone on my plow so this info helps.
bob9N wny
02-27-2005 17:13:35
 Re: Dearborn 10-156 in reply to Poppey, 02-27-2005 14:04:32
POppy
sorry but I cant help you with hole size or where to get new ones. You could do what I did and find a pair you can make work.
bob
Scott PA
02-27-2005 17:11:41
A New Holland dealer near you will have new 15 1/2 inch discs available or if you can't find any click on my name to email me for more info.
bob9N wny
02-27-2005 08:09:19
I checked my Economy Plow manual and found the following
10-174 15 1/2" plain disc
10-175 15 1/2" notched disc
10-176 18" plain disc
10-177 18" notched disc
I have a 10-156 and it has 15 1/2" coulters on it
HTH bob
Poppey
02-27-2005 09:10:42
 Re: Dearborn 10-156 in reply to bob9N wny, 02-27-2005 08:09:19
I measured the old ones and they are about 11", the most I could put on is say 14-15"? What do you think? Maybe a different plow than I thought?
